removal of hub cap and wheel
noddy - December 27th, 2008 at 09:48 PM
just bought a kombi and would like to know easiest way to remove hub cap and tyre do u need special pin type pronge to remove cap,
ian.mezz - December 27th, 2008 at 10:09 PM
just use a big screw driver under cap and pop it off no special tool needed
Bizarre - December 27th, 2008 at 10:11 PM
yes - there is a special hub cap removal tool
http://www.aircooled.net/new-bin/viewproductdetail.php?keyword2=EXA0004&c...
but most people use the flat blade of a tyre lever or large screw driver.
depends how pristine your rims are
Barry
whatnow - December 27th, 2008 at 10:13 PM
i always used a screwdriver on my beetle but the hubcaps were stuffed already.
i would imagine that with a wire coathanger and a pair of pliers you could fashion a suitable "hook" to get the cap off.
noddy - December 27th, 2008 at 10:13 PM
will get big screw driver onto it cheers thought thats all i had to do,
whatnow - December 27th, 2008 at 10:16 PM
wow you've got to be quick here... i guess i should use two hands not one finger to type.
Matt Ryan - December 28th, 2008 at 07:15 AM
A claw hammer works well on the early domed hubcaps, just place the end of the claw under the rim of the cap and use handle of hammer to lever it off. You can tape a bit of cardboard or rubber to the head of the hammer to protect paint.
Regards,
Matt.
modulus - December 28th, 2008 at 11:10 AM
You can make one like the illustration, then slip the shaft of a screwdriver through and lever off the tyre. No scratches on the wheel or hubcap.
hth
Joel - December 28th, 2008 at 04:33 PM
i madeup something like Peter showed above cos one of my bugs had wide wheels and cos of the offset u couldnt get anything in there to lever the hubcap off
