Can anyone recommend anyone for a minor rust repair around the rear window on a 71 bug? In sydney to wollongong area.
thanks
U have PM...
cheers Dean....
hey dude, no pm? the system might be playing up.
if its the rear window then it won't be minor.
It shouldnt be too bad, I am aware of how bad they get around there.
remove the engine and sound deading B4 you get the rust done
and before you give to the panel shop remove the FOAM sound dead material up in the rear pillar
it will make a much better job u need a hook rod to pull it all out both sides
after you have got the foam out get some CRC carby cleaner and spray in the cavity a few times to disolve the residue of foam sticking to the walls
of the cavity
cut it open
foam stuck to inner cavity
