will unleaded fuel
RATAFIED - April 23rd, 2009 at 12:02 PM
make the car misfire and cough and splatter,my SQBACK that im building ran out of fuel so i put about 10 litres of unleaded in it and know it is running real rough and stalling
thanks mick
DirkHedde - April 23rd, 2009 at 01:23 PM
where the hell have you been buying leaded fuel these last few years?! unleaded fuel is no problem with these motors as they were designed to run on it so that is not your problem. i reckon it will be the fact that you've emptied the tank completely and suck up some crap from the bottom of your tank. maybe check your idle jets you may have a blockage in one side perhaps?
vw54 - April 23rd, 2009 at 01:34 PM
if it ran dry and you added fuel u may have stired up crap in the tank n carbies
start at the front pull and clean all fuel components till u get ot the back of car and carbies
68AutoBug - April 23rd, 2009 at 02:11 PM
leaded fuel has been illegal for a few years now...
If You had any, it would have gone off anyway...
and clogged everything up...
old unleaded petrol breaks down and also cloggs everything up... including the carby..
I use premium unleaded fuel... 95 or 98 Octane..
and tune my engine to suit...
VWCOOL - April 23rd, 2009 at 02:32 PM
yeah you have sucked up crap and maybe moisture form running your fuel tank low/empty
Inspect/clean filters and fuel bowls
RATAFIED - April 23rd, 2009 at 03:05 PM
i have only had the car for 3 months and im rebuilding her so it hasnt left the back yard ill have to check everything the fuel filter is clean i can see know crap in there
thanks for the info guys
RATAFIED - April 23rd, 2009 at 04:48 PM
i read some where about a carb balance pipe taht goes from carb to carb some how it had came off one carb i pluged it back on and know it sounds right
matberry - April 23rd, 2009 at 09:45 PM
A backfire (probably when running out of fuel or restarting) probably blew off the pipe. Nice to have an easy fix:smilegrin:
greedy53 - April 24th, 2009 at 07:51 AM
well here is a good chance to redo all the fuel lines ,and rubber pieces a good job that needs to be done ,so where do you start remove the fuel tank and check the filter in the tank and from there just follow the lines and replace all including the filter and you never know there mite be 2 filters on the line. on an older car this is a must if you dont want hassels down the line and a fire whitch is a common thing for old vw's mainly caused by rubber leaking on to dizzy or genny the little sparks ignite the fuel and you dont have a car anymore just a bbq and no snags to cook
good luck
