http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=180394748197
Is this a 70's with an oval window grafted in? Or is it a 56 with a 70's rear clip welded on?
Hmmm
Going by the size of the rear side windows i'd say 70's
i would stay clear of that one
its a late oval body with the flat inner door skins
just had the usual 70s-80s treatment of a late decklid and valance, hacked up dash and dropped onto a late 1300 floor pan
whatever it is, I dont think it will sell too quickly.
Although, it does have turbo seats!
1969 if you ask me but obviously been messed with, very similar car at the hot rod show on sunday, took me a few walks around it to work it out.........
geez cant people pick 6 volt side windows
theyre nearly 2" smaller than 12 volt bugs
Absolutely Joel, it's an oval body shell (pre 1958) without any doubt. The side windows are considerably smaller than the later 12-volt ('68 and on)
body shells.
In this respect it is like the Brazilian Beetle (Fusca), which never upgraded to the 12-volt body. They kept the 6-volt side windows all the way
through. Here's a picture - have a close look at the door and side windows and see how they are the same as the early 6-volt VWs.
Another way, if you aren't sure, is to look at the vent window pillar. 12-volt Aussie Beetles ('68-on) had pillars that sloped backwards slightly.
6-volt ones were perfectly vertical.
you cant see it cos theres no front on pics but ovals also have different shaped windscreens to 58 on bugs
Phil, ive got a mate in bolivia who owns one of those brazilian bugs
its a real oddball
only 70s bug ive ever seen that has a factory manual choke
its got a 6 volt dash like early 60s aus bugs but it has a vynil skin over it but nothing like normal padded dashes
quote from egay ad:
"BUYER WILL NOT BE DISAPPOINTED......"
i was but i couldnt keep a straight face with the tears from laff'n so hard..
in answer to your question
its what ever you want it to be..
you know you want it..
(insert seeing eye dog emoticon here)
Yer i belive it's a genuine oval but it definitely has had the rear apron changed to the later model one for the decklid to fit. I actulay like the
look of that i think the oval looks good with that later apron and decklid and 60s tail lights.
From Dylan The Dubber
If I had a flame thrower I'd torch you both!
