Hi All
Can anybody tell me were the best place to find a new wiring harness. Absolutely fried mine in the baja today. we tried to fix but problems
just got bigger and bigger. Can you buy kits including new fuse boxes,diagrams etc? Baja has still the Original 1960 wiring by the looks and i have
been lucky lasted this long. Any info would be great.
J J
maybe Vintage VW supplies in Sydney? Classic Vee Dub? Mick Motors? second-hand (if you can find)?
what part fried? Maybe you can repair circuit by circuit
Try vintage wiring harnesses as well. I think it is http://www.vinwire.com.au from
memory.
Yogie
I got mine from ebay about $120 if i recall correctly.
Hi all
Thanks for info will check out. Wires melted from ignition thru to starter motor we think? plus the positive and negative wires to the electric
fuel pump also fried to the point of no return.The baja just stalled as if i was out of fuel, then the more we tried to start the more wires started
to melt. We then lost power to starter motor,we noticed smoke pissing out of the front so we had to disconect the battery. Luckily we were only 2 kms
of the main road and did not have to push all the way home about 20kms, a guy gave us a tow and got us out of the manure. All the wiring and fuse
box still looks original being a 1960 vintage probably well overdue, so now the fuel pump u/s and baja off the road may as well give the old girl a
birthday.The carbies can come off and be rebuilt , the 1835 can also come out and be freshened up and there is a oil leak in the gearbox so might
chase one with super diff. will keep u posted with progress.
JJ ![]()
Vinatage wiring harness made mine approx 7 years ago, with extra wiring for tach, oil temp and pressure inside the conduit, from memory it was around the $400 mark, but I am sure the website has prices
