hi, im tryin to fit a fiberglass fan housing [porsche type] if you have one or have fitted one, how did it fit, did it seal well, is it tight around all the barrels, did it slip on easily, do you think it cools as well as a dog house setup,,, thanks for your help........ greg
You need to speak to BIGRUDI. He has one on his race car and swears by it.
Kev
thanks camo
Give Holzl a call
or Ian Swinkles.........Lukes was a pain to fit on the dual cab
my fan
thanks, does it bolt on to the head wit the small screws, the one i have has tabs but nowhere near the place it should bolt to
no mine is held down by the inlet manifolds,tight fit once there bolted in everything stays in place..![]()
not sure if they are for sale but saw a bunch down at rod penroses place when i was last there... give him a bell, im sure he has on he can spare.... failing that try some of the mainstream vw suppliers, ie cbb vvw etc....
