Does anybody know the weight (or its approximate) of an early type 3 (pre '70) fastback body only, off the flloor pan and WITHOUT the windscreens,
interiors, front and rear guards and doors ?
I am trying to suspend it for a few months while i'm working on the f/pan. The garage is not big enough.
Thanks all in advance
It's light enough for two blokes, one on each end, to lift without too much grunting. Ought to be less than 150 kg.
Thanks Phil74Camper.
I should be able to do it then.
What are you planing on suspending it from?
