I was at the action day and happened accross a linkage that i need but i have had a search and can not find it anywhere, maybe im looking in the wrong
place. If its your car or know them please could you let me know how i can get my hands on one. It needs to go behind the shroud.
That would be a modified CB performance "hex bar"......... extended arm links and air filter bases flipped form one side to the other
The arms he used look to be manufactured that way, is there a kit from CB that i could get a hold of. Otherwise I will have to look at twin pull cable linkage kits.
Oooooooooo, it's a PHANTOM linkage..........
http://www.cbperformance.com/catalog.asp?ProductID=1260
try Vintage veedub Sydney I think they fitted the A/c
Wouldnt those long arms flex??
What if you flipped the carbs around ( http://www.cbperformance.com/catalog.asp?ProductID=501 ) so as the arms were short.
Adjusting the droop ros the first time would be a bitch but with the filters off would be doable??
works well
wouldnt most applications where you would be wanting that linkage be using the doghouse cooler?
Excellent, Thank you for the directions.
As to the cooler I will probably run an external with this linkage.
