Hi Guys,
I thought I would let you in on a great Oil Filler Bottle I got at SuperCheap the other day for about $7. It is a replica of the Glass Oil Filler
Bottles that were help yourself at Petrol Stations in the 70's and earlier.
It holds a litre and makes filling a Beelte or Upright engined Kombi a simple affair. There is a trick to using it to make sure the breather hole is
at the top, and block it with your finger while you are walking to the car so it does not spill out.
I was always terrified with Oily hands using my Antique Original Glass Castol Bottle.
Cheers,
David
Ive still got the real shell & solo ones from the days of drive way service.
Solo ??? You mean soft drink used to come in them too ???
btw - the Newman's servo down the road still has a crop of those bottles out the front - almost look like they're left over from the 50's and all
I use to use them in the 80's when I worked at the ampol with driveway service.
I saw some at a servo on the way to dubbo at Christmas.... Thought it was a bit oldschool. Most places want you to chose (so it's your problem) yout own and take the half empty bottle with you. Then you can add the plastic to landfill and dispose of waste oil in an un-environmentally friendly fashion. Sad hey?
