Hi All,
Saw these mirrors on one of the cars today and they tick all the boxes for what I'm after with the indicators in them.
Anyone know where I can find them (and what the damage is likely to be)?
Craig
They look a hell of a lot like the Vitali California's (Joel has them on his car) that you can get from Revolution Racegear, but I've never seen them with the indicators in them. I would also be intersted to know where you can get these from if anyone knows.
i want a pair too they look really good, they were on a couple other cars from memory too
http://www.revolutionracegear.com.au/index.php?PCID=10307&PSO=245&PSI...
They are Vitaloni mirrors -but I have not seen them with the indicators.
The range is limited in Australia and some people buy them on Ebay or order them from overseas.
I lost one one mine when it fell off on in the middle land of the M4 motorway and got run over by a semitrailer :-(
They are on Steve Natoli's car
Send him a pm (sick68)
craig,
try a hot rod supplier, i think they might be from vision concepts or something similar,
i have some mirrors on the grey car with indicators in them and i vaguely recall that being the name
Nath
Thanks Guys,
I'll give all of the above a try, but I suspect that it is a home modification job (albeit a very good one).
After the comments I saw this morning before running out the door I gave them a closer inspection today, and you can see the silicon around the edges
doesn't look like a factory job.
Still damned impressed though and figuring out how I could go about it if needs be.
Craig
if i knew you wnted some, there was a guy at the gold coast show recently that had 2.5 of them, cheap too, one spare glass
would be easy enough to do, though like i said at the car, im curious where the wiring runs but cant think of anything else other than the middle of
the base i guess you would call it
still like the ones from jeffreys though
Sadly I don't think these would suit Gwendolyn:
https://www.americanautos.com.au/cgi-bin/fccgi.exe?w3exec=aap.control&ses...
