I have a Lexmark X4550 printer which I bought new..
the original cartridges were replaced with new Lexmark ones
and then I refilled the original ones..
I have also bought New Generic cartridges which won't work..
I put the original cartridges in [now full of ink] but the ink level still showed they were nearly empty.
I had to use the color cartridge to print in color...
Now it will not print...
it says to reorder NEW Lexmark cartridges...
is there a way to confuse this printer??
it seems the cartridges will only work until they should be empty....
Is the memory in the Cartridge or in the printer???
Any Solutions????
buy a cannon!
I also have a Lexmark printer, an older Z42 (I feel some loyalty to Lexmark as they were once part of IBM). I have never had any luck with drilling
and re-filling the cartridges - my printer still works but the jets clag up and/or smear. It's currently using non-genuine 20 and 70 cartridges that
I bought on Ebay for around $25 each. Genuine Lexmark are around $60 each.
Not sure about later Lexmarks, but there should be an option to 'set' the cartridge as 'full'. Try right-clicking on your printer and select
Properties. There's usually a graph showing how full the carts are. Somewhere nearby should be an option to set 'new' cartridge - it might be part
of the 'test print' function.
yeah, filled mine the other day, and it says empty. i just tell it to print anyway.
Many cartridges contain a "chip" which tells the printer when it's empty and that it's a genuine product. Some refillers have the equipment to
effectively reset the ink counters when they refill your cartridge. I'm not 100% that Lexmark use this technology but it's getting common these
days.
My HP even tells me when my inks are supposedly out of date.
EDIT: If you print a lot of black you should consider a cheap mono laser printer. A brother HL-2140 can be bought for $85 and comes with a 1500 page
toner cartridge.
yeah Lee it is really worth doing your research on inkjets. What seems like a good deal often ends up costing a small fortune to feed!
Lee the cannons seem to have no problem with refills. mitchell
go canon i refill mine all the time just get the refills from supermarket or bigw
or HP I refill them as well cheap as and print quality still great even for printing of pics
HP Officejet All-in-One refill comes with a sticker to reset ink cartridge when you refill it
and the Canon printer still prints when it says it's empty so it doesn't matter about reseting it it's at home I will let you know what model it is
when I get home it's a multi function one.
My canon is a Pixma MP180 i've had it for a few years now all good. It's great for printing off your vw pics from shows.
http://www.canon.com.au/en-AU/Home-Office/Printers/PIXMA-InkJet-Printers/MX350
Thanks Rose..
I found it much more inexpensive to have My pics done at Big W or Harvey Norman.. 10 or 15c or 25 c each...
and You can have larger pics done too...
You can also add Merry Christmas etc on them
or change the colors etc...
move the car etc..color cartridges ?
and can You change just one color???
I can do all of that and more with my picture programme in my comfy chair at home.
noice cards
[size=5]EXCELLENT WORK ROSE
GREAT CARDS....
although they were ugly dogs...
thanks Rose...
Have a nice quiet & Safe Christmas.....
[/size]
