HI
My Beetle is a 1968 German made semi auto beetle with chassis number: 118 714 109
VW311 511 245
VW311 511 246
VW111 511 245E
are three part numbers I've come up with...
[from somewhere?]
Someone with a 68 auto beetle sent Me an email or PM with 3 part numbers over a year ago...
that He had used....
could have been from the USA..?
so, which part number do I need two of???
I may have 4 nobby types... but are they different??
This may help.
http://www.vw-classic.net/index.html
http://www.vw-classic.net/et_katalog1970/380-381-29+A29.pdf
http://www.vw-classic.net/et_katalog1970/382-399.pdf
hey lee
does poly-urethane make a lot of difference??
And do u bother to lube up the poly urethane in any way when fitting?
Hi Lee
The inner ones are knobbly, 311511245 and 311511246 thats left & right. The outer ones are smooth and round on IRS bug.
You should also do the inner trailing arm pivot as well.
I've never worn out a set Urethane bushes, I lube them with Never Seize.
I lube the rubber ones with Talcum powder, fragrance to owners choice.
thanks Steve,
thats what I concluded too...
for M9 on the German parts catalog...
going by chassis numbers...
I was guessing that M9 may have been automatic beetles???
as no manual beetles had the IRS in 67-68 models..
[not years]
I'm going to buy two of each....
do You mean the pivot bush needs replacing??
My Son renewed those and they kept coming loose...!!!
the special bolt that is..
PS I'll be using rose smelling talc... lol
CIP1 part numbers were 311501245 & 311501246 ??
