Is there a website where you could check the engine/body numbers to see if they match. The reason I ask is my notchback seems to have a noise coming from the main bearing. And I can get a replacement motor for it, but would rather keep the other one if it is original.
I don't know of any websites for the type 3 then again I've never looked.. lol
put Your engine and chassis number on here..
I'm sure someone can help
What a strange sentiment. Surely if you don't even know now whether your engine is original or not, why would replacing it with another one matter?
The easiest, but not necessarily most reliable, way to check whether it's the original engine or not is to look on the rego papers. Engine numbers
are recorded on the vehicle registration database, and in my experience people generally don't bother to get it changed on their paperwork when they
do an engine change.
its not a strange sentiment ,as in a few years time when people are looking for matching numbers cars they are worth more dollars.And in NSW yearly pink slip inspections would show its not changed and the records would be put right..
I don't think there'd be many VWs left still with their original engines. It's probably important in the expensive classic car scene - does that
Deusenberg or Jaguar E-Type still have its original engine? But it's not something we check at the concours judging at the VW Nationals, except for
context. You'd expect an oval to still have a 36-hp 1200, and a Superbug to have a twin-port 1600, but otherwise no one knows or cares if the engine
number is the exact original. Yours might not even the same engine now that it left Clayton with. Flat Four didn't check engine engine numbers at the
Shootout either, and no 1500 Type 3 ever lost points because it had a new 1600 long block in it. Unless it dripped oil.
I don't think the Australian assembly records, of what engine was fitted to what chassis number, still exist (if they ever did).
I think you could replace your existing Type 3 1500 with any rebuilt similar engine and no one would care. Changing the number at the RTA is not an
issue if it's the same type. By all means have your existing engine rebuilt if you want; contact your local VW specialist.
Hi, I've occasionally wondered if mine has matching numbers and assumed it didn't because my mum said something about my dad having had a
reconditioned engine put in and we're not even the first owners, but I thought I'd check just for the sake of it. The chassis (under the seat) has
3642029, and where I've circled on the pic has 6792904... are they in any way matching for what is supposed to be a '61 bug? Cheers.
Link to Type 3 chassis number/engine number info: http://www.thesamba.com/vw/archives/info/serialnumberst3.php
As has been said, use rego papers or delivery papers if you can as Australian numbers can be screwy compared to German records.
Either way, get the noise investigated as, depending on what the noise is, the case may be saved if it is a bearing letting go and it is caught early
enough.
