Gday, can you put larger barrels and cylinder heads onto smaller engines (ie 1600 barrels onto 1200 motor) to increase thier cc's without major
mods.
NO THERE AINT ENOUGH MEAT
IF U ARE GOING 1600 THEN U NEED 1300 OR 1500 MINIMUM
The 1200cc cases are different and can't be converted to 1600cc. Any of the 1300cc, 1500cc or 1600cc cases are essentially the same and will accept 1600cc pistons, cylinders, heads and manifolds to upgrade it to 1600 twin port.
you can put a 1398cc big bore kit on a 1200cc motor
but with twin carbs they had much more poke than the old 40 ponies! 1500 size heads became readily available when
the industrial engines lost one side for the compressor head. We were paying around 50 bucks for a complete head in about 1968.That's a pretty cool story 1500S. If you put enough effort into it you can do anything, but as I'm sure you realised I was trying to say which
conversions were the easiest. Once you've gone to the effort of putting in a new crank and machining the cylinder holes out, instead of going up from
1200cc to 1600cc you could start with a 1600cc case and then put in a stroker crank and/or big bore pistons, taking you anywhere from 1835cc to well
over 2 litres. This all requires expense though, and new parts and machining time. If you don't have an engine to begin with, then I would suggest
that buying a complete 1600cc engine is easily better value for money than building one up. I've bought a good running 1600cc twin-port for $800 so
you should easily find one under $1000.
So, if your car has a 1200cc engine, I would recommend deciding whether you care about keeping the 'vintage' style originality or not. If you don't
mind, I would recommend a swap to a complete 1600cc twin-port, and keep your 1200 motor in the shed in case you ever want to restore it to original.
If your car has a 1300cc motor or bigger which has a bottom-end in good condition, you can then decide whether you want to bother swapping pistons and
heads or just swapping the whole engine. If you're interested in a real go-fast motor and you want to go over 1600cc, think about getting a second
engine as a basis, and keeping your old 1300 or whatever as a spare. That way, you can drive the car with the 1300 in whilst you're building the hot
motor, and then once the hot motor is in, if you ever want to sell the car, just put the original engine in and keep the hot one for yourself. This is
necessary because a decent high-performance engine build will cost you thousands, but it does not necessarily add thousands of dollars to the value of
the car.
What I was replying to was "The 1200cc cases are different and can't be converted to 1600cc" which isn't true as I have stated, a good story or
not. I did say that from a 1200 conversion to 1500/1600 all you would have from the original was the case. The base casting of the 1200 and 1500
cases are near the same and many were converted during the 60s. On here we see quite a bit of misinformation regarding what can be done and what
can't. We also see the output of twin port over single port where there are claims of much more power from the twin port with the standard single
or standard dual carbs. The VW engineers couldn't get any increase so what hope do we have! Likewise with torque from FI over
carbs................ all the same. The fact is that that the twin port heads were developed for the fuel injection setup which gave better polution
control, not for power increase etc.
So, back on topic, can you put larger pots on a 1200 case without costly mods? Yes, with the same crankcase mod as a 1600 going to 1916, that is the
holes bored to accept the 1600 pots except that the standard 1500/1600 heads can be used so the cost is much less.
DH
so what about putting twin port heads onto the 1200 single port. was thinking of doing something stupid, like turbo or blower just for shits and giggles. And just because i can!
As a fond long term member of the association of laziness and slack, it is my duty to show some neat, cheap (in comparison with time and money)
options that will give ur bug a little more go go juice.
I was trawling ebay and see the stuff u can score ![]()
dirt cheap 1300 running cc engine (then nab some 1600cc heads and pistons for a couple extra hundred, and there is no need for case machining! You
could be done in an afternoon!)
http://cgi.ebay.com.au/vw-1300-motor-/160482909752?pt=LH_DefaultDomain_15&...
Carb kombi 2ltr
http://cgi.ebay.com.au/VW-1800-KOMBI-TYPE-4-MOTOR-ENGINE-/220671993664?pt=AU_...
EFI Kombi 2ltr
http://cgi.ebay.com.au/2L-VW-Kombi-Motor-/330474232444?pt=AU_Car_Parts_Access...
There are always dub engines popping up there... suprised there isn't any normal 1600cc ones... if u check each week there will eventually be one.
though there might be crank issue's. interesting to find its limit with the blower though.8-10 psi? before heads get blown off.
