Hi all, if I remove my front and rear beetle bumpers and weld the bracket holes up or install T-Bar brackets will it fail a roadworthy?? I am in NSW, thanks
tbars yes they fall in to the dangerous protrusion category.
running without bumpers is kinda a grey area. if you really want to know ring the tech support line at the rta and ask. they will give the straight
answer but it may be the one you dont want to hear.
The word from another forum is that T-Bars are illegal but people run them with no issues, bumper removal doesnt seems to be a problem, the main RTA test is to walk around the vehicle and if you knock your leg on something sticking out you might fail, but havent heard of anyone failing a roadworthy for it and I guess the only thing that will stick out is the exhaust (in that case get a hideaway)
what happens if you coat the ends of the T bars in a dense foam/rubber ![]()
pool noodles
I removed the bumpers from my RSK and no worries getting the Vic RWC or rego
Raf
Looks like a car that never even had bumpers ![]()
Kieran as I said on samba its not legal on paper but depends whos inspecting.
100s of people have run them for years and not had hassles but it doesnt mean its legal.
Falls under the same category as eyebrows and decklid stands offs.
Niether are legal either but people everywhere run them
I got pinged years ago for running eyebrows but not upset,
eyebrows on latemodel cars = fail.
Bonus fail points awarded if they tilted on an angle to look even more stupid
I have a set of T bars here for a 68 on if your interested.
someone should make dense rubberised chrome t bars!
I got rejected for not having a rear bumper but it does depend on whos checking the car.
as far as pedestrian safety goes a solid metal bar vs more solid metal could be argued; in either case if your hit by a bug then expect broken shins!
