Is the rear wheel nut on a 89 Caravelle left or right thread. Cheers.
right hand normal threads
just reading your other post about brake linings & you shouldnt need to undo this nut just to change brake lining on a T3 Caravelle. Brake drum
should come off after the removal of a 10mm hex head bolt if i recall correctly. Hub will stay in place, unlike a beetle drum brake where you have to
remove the axle nut.
Brendan
Yeah meant axle nut,hub is in the way to remove springs and adjuster. Nuts were very stubborn,never been off by the look of it.
