Hi everyone. Is there an adjustment you can do to the indicator switch? Mine won't stay on and it is really annoying. I've tried cleaning it but that didn't help. It's on a 64 bug. Cheers
No adjustments.
Probably old age.
I suspect you may need a new switch.
No worries. Thanks.
You can disassemble the switch and using a dremal clean up the step on the boss were the tab sits when it is in the on position, i just did this to my
karmann ghia switch
and it works as it should.
