Oil in heat exchangessurfdub - October 22nd, 2012 at 07:40 AM
allo all need some help
so theres oil in my left heat exchange...
do i pull it off and blast it full of brake cleaner? and wash it down or is there something else to do?
Jordan
68AutoBug - October 22nd, 2012 at 09:11 AM
Originally
posted by surfdub
Jordan
this is usually from a leaking tappet cover [very common]
I use the cheap foaming degreaser spray available from all the cheap shops for $2.99 approx
the foaming one is the best...
Just spray everywhere You can to get at the oil, wait 3-4 minutes and hose it off.. You can repeat it as many times as You need to..
PS: the oil doesn't seem to get inside My heat exchangers
as they are pretty well sealed.. but I do smell burnt oil sometimes when I put the heaters on.. the oil gets burnt up fast.. I do spray all under My
engine etc every month to get rid of any oil... cheers.. LEE
