Hi guys does anyone know where I can buy the torque dude tool for the rear axle nut and flywheel? MMA site says out of stock.. Thanks in advance!
torque dude?
Prolly the kit for tightening the 36mm axle and flywheel gland nut's. Be wary, I bought one from the US (different supplier than this) and it's a
piece of sh1t. Hasn't worked once. Lucky I have the big gear
http://www.piersideparts.net/LR000133.html
is it accurate?
It would be totally acurate if it worked, as Matt stated his is a piece of crap, it is a torque multiplyer, 10 to 1 gear ratio, we use this type of equipment all the time except it is slightly higher torque values, 2000NM and up, hydraulic one have taken over from the manual type in the industry that i am in.
Got mine from CIP1.
Excellent bit of kit!
6 foot of bar with a 36mm socket welded on has always worked for me and with the flywheels i just bolt on another bar that picks up 2 of the clutch
pressure plate bolt holes .
Yes i can't tighten to any setting other than FT but it hasn't failed me yet .
The top tip though is NEVER tighten your gland nut with a big rattle gun as you have no feel over it and if you have split the nut with over force
then when that flywheel comes of it's gunna make a mess
Try this fella, I kinda remember he makes one that got some good reviews, you will have to go down the posts a bit.
http://forums.aussieveedubbers.com/viewtopic.php?tid=97475&page=1#pid908691
Torque meister - they work fine.
I donated one to club vee dub sydney.
