Hey All,
Its happened again! Another project that was unable to be completed. A chance for someone to start at the fun point of a project.
•Price - listed below
•Location - Sydney, Concord 2137
•REGO - Yes
•Contact details - Alex holzl 0415 Two Nine Two 220
DETAILS
BODY
-Firewall moved forward
-paint Stripped
-Painted last week (late feb 2014)
(Porsche yellow, $1000 per 4 litres)
-Late rear apron EFI fitted
-Late a/c front apron fitted
-Doors for one piece glass
-Factory window scrappers
-Front and rear powder coated bumpers NEW (silver)
-x4 aero guards – trimmed and fitted ($1500)
-993 GT2 rear boot lid ($1500)
-L-Bug body and parts painted (7000)
Cost well over $10000 (See below for body chassis combo)
CHASSIS
-1971 pre-ADR chassis with Rego papers and rego (Pre-ADR allows less compliance rules for rego)
-Chemically dipped $200
-Powder coated chassis $300
-All suspension, struts, tie rods, stub axels, lower control arms have been powder coated
-Seam welded tunnel and forks
-Fork stiffening
-Berg gearbox mount; suits engine and gearbox 35mm forwards
-28mm torsion bars $240
-Powder coated front struts with 944 Porsche inserts $1550
-Eibach springs with helper springs
-Poly bush kit, front and rear $150
-Front Boxster 3.2 brakes (new pads front and rear), discs and hubs to fit vw stub axle
-Rear 944/964 alloy callipers with mechanical handbrake.
All brake parts total $1600
-T2 (kombi) drive shafts and new CV joints, boots and axels ($800)
-Braided fuel lines and oil lines with bulkhead fittings, run through tunnel
-Fuel swell pot mounted forward on chassis
-Clutch tube; additional support added
-Tunnel treated for rust prevention
Cost over $4840 (see below for body and chassis combo)
WHEELS
-18x8 and 18x9 Porsche wheels (non-genuine)
-225/40/18 Front and 255/35/18 Rear Federal 595 RSR street/race rubber, Brand New
Price to sell $2000 (included in body and chassis deal)
ENGINE
-Type 4 case $800
-Chemically cleaned
-Bored for 105 or 103 barrels
-Standard bearing size
-1800 rods, small end re-bushed (will need reaming to suit gudgon pin size of choice) $280
-Case half studs and cylinder head studs cleaned
Total $1080 will take 600
HEADS
-Genuine type 4 square port factory cylinder heads $800
-Welded and relocated spark plug hole
-Big valves fitted 49.3mm inlet and 38mm exhaust
-Manley extreme duty stainless valves to suit
-Valve seats cut
-Reshaped chambers
-Guides serviced
-Ports semi-opened up (cylinder heads still require more porting to suit engine spec)
-Cylinder heads glass blasted
-Fly cut to 103-105 barrels
-Chev offset valve collets
-VW/Porsche 914/1700 Rockers to suit 911 Porsche swivel feet tappet adjusters
-Berg T2 Moly rocker studs
-Chev triple valve springs
-Chev Chrome Moly retainers
Total $2600 will take $2000
INJECTION/MANIFOLD HARDWARE
- Plenhams and pipes to suit fuel-injection around Porsche fan (polished alloy)
Cost $800 will take $500
-2 xT4 manifolds welded for extra porting
-Fuel swell pot with fuel pump mount
-Fuel injector pockets fitted
-Haltech E6x ECU with x1 VW loom and x1 new loom $500
-Comes with hall effects sensor
-x4 380cc injectors 2nd hand (free)
Fuel injection hardwear + ECU and 2 looms $1200
GEARBOX Total cost $5000 will take $3500
-Custom ration 1st, 2nd, 3rd, 4th
-New bearing
-Super diff
-Tall 1st and 2nd
Still to be assembled by dave butler at our cost.
SOOOO HOW MUCH????
Total for all parts adds up to $28,020!! but this does not include labour or all the little parts all along the way. this is just the big bits and
paint job!
- Will take $16,300 for allllll
OR
- For body, chassis , wheels and brakes $10,000
-Engine parts and fuel injection $2800
-Gearbox $3500
We may seperate the body and chassis but would like to have 2 buyers before seperating.
I hope the value is seen here and someone can make the most of it.
Very nice ![]()
Cheers craig, its a shame it couldnt be finished.
make an awesome German Looker
What a shame, I've seen this car being built from the early stages, no shortcuts on this car
Does it come with the seats, steering wheel, gauges, and all the other parts like window glass and winders, lights etc etc ?
Yeah seats that are in it. One bucket and one reclineable with mounts.
Unfortunately a lot of these parts have been lost. We are working on getting glass and rubbers at the moment.
I'm thinking a very cheap donor car will be the go for all the odds and ends.
Brackets included for front brakes.
Gone on Craig , you know you want to !
Why is the paint $1000 for 4 litres? Is it special magic paint or because the word Porsche is in front of it? Surely the same colour can be had in a 2
pac for a lot less?
Just curious?
Yeah it is Porsche paint. He wanted it for the exact colour.
you know it would look good in your shed Craig ![]()
not sure I go for the 90's Steve Carter look
Lose the rear engine lid and it may start to grow on me
Hi Craig
I nearly painted my new bug Suzuki yellow, but I knew that there were other yellow bugs in pipeline so I went with orange.
I'll paint the standard boot lid for you Craig!
Considering parting the one whole car. Send a pm if your interested.
Body chassis and gearbox sold pending payment
nice stuff young fellor....good sale
