Moderators please remove if not allowed
$34,000
1979 UK delivered original RHD 911 3.0l SC
This car was originally white. Has been re sprayed Viper green about 4 years ago. has gone through a major refurbishment. The list of brand new parts
is long and it includes:
- new fuel lines, fuel pump, accumulator and filter
lines
- full major engine service (outside the car) including manifold boots, oil pressure switch, thermostat seal (no oil leak on this car), hydraulic
tensioners, plugs, etc
- new suspension bushes for front and rear sway bars
- new clutch, clutch cable, pressure plate and thrust bearing
- new tires
- reconditioned alternator
- new carpets
- fully reco'd 5 speed gearbox with receipts
- iPhone enabled bluetooth tereo
I have receipts for all of the above
It had some rust under the fuel tank when I bought it that was fixed, I have pictures. Has two bubbles that I can see, one under the front screen
rubber and one under the rear. Floor pan is clean
Nothing to do on this car except drive and enjoy the power of the 3L SC engine
I spent a lot of time, money and effort getting it right so it is sorted, you won't be buying someone else's problems
Was previously registered in NSW. Now on club registration in Vic
Can be inspected in Kew East
Raf 0448 808 216
SPANK ME !!!
Sold
