1996 VR6 Passat Auto
Pictured with 17" BRM's but Car comes with Std VR6 15" mag wheels.
Jan 2016 rego
Paint thin on bonnet n roof
$1,500
Campbelltown NSW 2560
Call Mike Waldron 0419402752
Have you got more info on modifications done to this car?
Car is stock as, I'm the second owner, its has a little bumper damage on front left and nere the left headlight, theres some paint chips on nealy
every panel.
I had these rims sittng around the same stud pattern, but they are to go back onto my bus.
The Passat was just a reasonalble tidy second car, but now not needed.
I drove this to the Melbourne VW show last year and it didnt miss a beat.
How many km mike?
Has it been lowered? if so, how? (cut springs, coils etc.)
Damn you Mike. Where was this 4 weeks ago......
Hi Daimo, it's around 230 something, I can tell more later this week, it's not at home at the moment as I've got it down getting a minor starting
prob fixed before it sells.
It's either a ignition switch or a fuel pressure problem, it winds over fine, fires up then cuts out. It'll do this 5 - 6 times then start n runs
great ??? But will get to to the bottom of it before I let it go.
Josh, yer a minor mod to the springs
but still
rids good, I fitted a new set of shocks in the back when I did this.
Mate... 4 weeks ago, a veedub badge n all I can see you in this.
Hi mate, does it have 5x112 or std 5x100 bolt pattern. just wondering if it has a towbar - bit hard to see in the pic of the rear so i thought i'd ask and does it come with reg. thanks mike.
Hi yer the stud pattern is the 5 x 100, I have drilled my T3 van to 5 x 100 and the van is also for sale and want to keep the wheels I have on the van
now.
No there's no towbar, would definitely be good for towing.
Yes it has rego till Jan 2016.
And I picked the car up this afternoon. It was only the immobiliser needed resetting.
Cheers Mike
And Daimo it has 232405 ks on the clock.
Car is SOLD
Starting problem fixed thank you Julian ![]()
And Nick enjoy it, it's been a great second car for me.
And cheers Aussieveedubbers I'm getting closer to that towcar I need.
