For sale FROM THE UK.
56 RHD Panel. Ex-Aussie bus
Overhauled last winter after not being used much recently.
Front bearings & brake pads on the CSP disks
Stock width beam with dropped spindles
Anti roll bar
Heating ductwork replaced / heating now fully functional
Wagenwest gearbox mount fitted to replace the old solid mounts / rubber mounts replaced
Leisure battery / intelligent split charge system
Engine bay rewired / under dash area rewired
New fuel lines
Larger tank & sender
Rear tail lights upgraded to LED's that now function as tail / stop / indicators & hazards
Centre brake light operates as normal
Working 12v semaphores
SA Conversion
1600cc engine
Remote brake servo & new brake pipes
Raised steering box
Automatic fire suppression system fitted in the engine bay
Can be supplied with a new full width RnR & pre-cut foam or an original Devon camping interior.
Can be supplied with 4x genuine Centreline wheels or 4x modified 66 only steel wheels with large logo SS hubcaps
Loads of photos here -
https://www.facebook.com/pg/vwJim/photos/?tab=album&album_id=101551195462...
I've split the advert down as each time I press post the thread it would crash and forget what I'd written.
Located in the UK. I can assist with the shipping at this end.
email is jim@vwjim.co.uk
Price 35k GBP
