After 4 years of buliding up my beetle its time for a new project its a fully restored 1968 semi auto conveted to manual its got 2pak red paint ,full
white inteior,4 wheel crossed drilled discs,koni shocks,geniene 16 inch fushs, adjustable front end with berg adjusters and caster shims
good 1600 motor 009,etc german running boards,1 year rego
$8000 ono
see pics in drag racing under comp attack
big head turner call 0414579538 stephen
So it doesnt have this motor in it that you previously described as below in another thread? What about the transmission?
90.5 x 78 engine is 2007cc
78mm bugpack crank vw journal
carllio rods vw length
fk89 with berg1.4s ratio rockers and straight cut gears
berg 12pound fly wheel
total seal ring dulite top gapless second
berg 40x37.5 heads
berg manifolds
48 ida manifolds with 3rd prossion port
kenedy 2500 pressure plate
4 puck berg clucth
9.1 compression
fully blue printed
gearbox is a
4.125 diff
berg mainshaft std 1st short 2nd forgot ratio
1.58 3rd 1.31 4th way to short
super diff
std cv's
I drive this all the time around the steet
Just looked at the pictures again...
are those rear guards widened?
What wheels and tyres are you selling it with? Those rears look wider than the front.
as is minus motor gearbox and yes comes with the wheels
:jesus
what are ya doing Steve????
Dont worry barry! Ive spoken to super and its all for a good cause! Your neighbourhood wont be quiet for long!
alex
