Due to some upcomming large milage weekly comutes we are thinking of selling our Baja Kombi and up dating to something a little more practicle.
In Breif : this is a 77 Deluxe that has been converted to a Baja by well reknown kombi baja man John Alder approx 10 years ago and once finished will
be quite a nice toy for who ever buys it , mind you i am not going to give it away as there is already way to many dollars invested in this
project.
For those that don't know it of late it is now fitted with an EG33 Subaru flat six that only had approx 36,000Klm when removed from the half cut and
has been dynoed at 169 rwhp in the bus this year at the Qld VW Dyno Day
The Good : Is fitted with the engine conversion and drives very nicely , has a new 2lt 091 box , 80% tread on BFG Mudders all around , a nice complete
factory black interior ,has factory rear slideing windows , most rust already removed and profesionly repaired , have an AC system to fit to it which
includes climate control.
The Bad: The front nose neededs replacing but will be supplied with the sale , passengers side sills need finishing , new 100lt fuel tank needs
mounting and shrouding from interior, rear floor needs rust repairs , cv's are a little noisy but probabley would be better with a dial in and repack
, alloy bullbar needs finishing , currently only has 1 month rego left and is still only registered as a 2lt 4 cyl but i will assist in this for the
engine conversion if it stays in Qld and help as much as possible if it were to move interstate , Is currently also quite patchy due to the ongoing
rustr removal but is primered in all areas with metal finish welded repairs .
So if you want a baja Kombi then this is the car for YOU !!!! Plenty of power ,and heaps of fun
As i said above , i am not going to give this away and would be looking for offers over $17,000.00
To veiw vehicle it is currentley located atr Custom Veedub @ Stafford in Qld or i can be contacted on 0411556744.
Thanks Andrew
What the hell!!! first the manx... Now the kombi!!! what next the towd? I'll swap my baja, for the kombi and the towd
ill give u my lunch money for her
