[WTB - SA] Gear shifter
V-Dubber - April 24th, 2009 at 02:16 AM
Im after the shifter (manual) for a type 3 fast back, around a '79 model...any one got one for sale or know were to source one from cheers!
vw54 - April 24th, 2009 at 06:58 AM
they stopped making Type 3s in 1973
V-Dubber - April 24th, 2009 at 01:47 PM
Originally
posted by vw54
Like I said in my other post im a noob to VW's I knew it was a 70's wasnt sure of the precise year, has no plates or engine, All I need to know is
if someone has a shifter (gearstick) up for grabs
greedy53 - April 24th, 2009 at 02:53 PM
where are you we mite be able to help if i knew where you are
bushed - April 27th, 2009 at 07:59 PM
the style and pattern are most prob the same as a beetle,(Not absolutely sure here) but I have one from a 72 super loks same from memory. plate
shifter and spring plus top and bottom rubber avail. 2x 13mm bolts and washers incl. pls e-mail
can someone confirm pls?
V-Dubber - May 2nd, 2009 at 11:44 AM
All sorted now thanks to Bushed !
cheers mate
