76 twincab project,couple spots of rust in drivers side but all other rust cut out and repaired.Has v6 holden with adaptor kit and heavy duty clutch
& pressure plate.
Some wiring needs to be finished off,3inch lift has been done.Reduction boxes fitted.
Interior needs some attension.
Couple pics here but can take more if needed.
Price :-$3000 neg
Contact :- 0421869958
email :- bundy_22003@yahoo.com.au
Shame I've got too many projects...... I've love to have a lifted Twincab again.....
out of curiousity, how far through the conversion is this, how much other than cosmetic would it need for rego? the other important question is, what weight can kombi's tow...?
Ah the mighty " Gyro " moves on again
is this the same dual cab which sold on here a few years back ?
Yes
How hard would it be for this to go back to VW power? Lots of body/metal work or bolt out/in motor and minor body work?
Penguin it was VW powered before as i have the engine mount...Don't think would be to hard just do the couple bits of wiring to ignition and starter
Derek
will be back in country early October. If you still have it I'll drop by.
penguin
