Chris
Woodside 5244, SA or Penrith NSW
0432014396
$4800 if picked up in Adelaide
**1972 9 Seater Deluxe Kombi**
Up for sale is my low light kombi. A great example of a kombi still intact inside and out with all the interior unmolested.
The body is very solid but does have some impections. Back right hand corner needs repairing. Easy fixed with the replacment panels available from The
Bus stop. Just cut and weld new corner in ($68 for corner panel). passanger floor has rust hole, rear left guard has small ding at front, bottom
sliding door small rust, middle right side panel has been slightly pushed in but would probably just pop out from the inside. I just cut out the rust
from the bottom front and welded new steel in, so is all nice and solid. New Light truck tyres. New Chrome deluxe strips. It has a 1600 engine which
was compression tested and tested good on all cylinders, but does need a tune which I will get done this week. Gearbox seems fine, engages in all
gears and no pop out. She is alittle loose when driving may need new ball joints. Interior is all original and in good shape except the drivers seat
which needs recovering. Over all she a great kombi that just needs alittle love to get her back to her glory. Car is in the Adelaide hills but may be
able to drive it to Sydney as am coming up that way in the next few weeks (Cost to Buyer).
photos
Is this still for sale? If so, any chance of a pic of the engine, front seat, and the rust hole? Also, info on rego.
