What: 56 Oval
Where: Perth WA
How Much: $18500
Why: Other Priorities at the moment
Contact: 0411 277 971
Forsale is my 56 original patina 56 oval in perfect condition. Built for the Nostalgia drag series with period correct 2276 with Italian IDA's in as
new condition, running original centerline rims. Original black paint and very good red interior (back seat some minor splitting), new hoodliner.
100mm narrowed beam with modified shock towers, drop spindles and adjusters. 4.375 gearbox with bugpack super diff, 4 german spider gears, heavy duty
side plate, welded third and fourth, bearing retainer plate, polished axles and triangulated 6 point race brace. Mocal 525ml oil cooler and fully
flowed thermostat controlled oil system. Autometer gauges and Innovate AF sensor in the glove box. Engine is fully rebuilt 2276 with new 82mm super
race crankshaft, scat chromoly 12 pound flywheel, CB 5500 super race rods, engle 130, scat rockers, WA drag racer Ron Harris prepped heads with 043
casting, extensive welding and porting, 42x37mm CB single groove valves with VW 650 valve springs, match ported manifolds with Italian 48 IDA carbs in
perfect condition, 39mm vents, CB 30mm oil pump. Scat 36hp fan shroud, alternator etc. CB Magnaspark distributor and coil. Produces over 175HP and
previously ran 13.29, with poor 2.15sec 60foot (normally 1.8), on street tyres at 104MPH. The new engine has not been raced and done about 1000miles.
The old flywheel dowels came loose, so the crank and flywheel are new as are all the bearings.
The car has awesome appearance with some cool pinstripe work and goes very well. Drives well on the street with lots of torque and smooth power from
1500rpm. Everything mechanical is new including brakes, steering and suspension parts. Everything works including semaphores.
Wow!!what an amazing car...
I bet its alot of fun to drive.
sadly way out of my price range..
Goodluck with the sale!!
Beautiful! Good luck with the sale mate- that's amazing power
WOW. Great looking/sounding package. Good luck with the sale
Hmmmmmm.....I can just see that with big No. 8s on it. How long would it take to drive a T5, with trailer to WA
You would be safer to transport it by truck, because you would find it difficult not to take your eyes off the rear view mirror.
Reduced $17,000
Very tempting.. very very tempting.......
That thing must sound awesome.
It will be a very sad day when this car leaves DeadKombil's place..... The coolest bug in WA.... No contest....
And currently the fastest too!
.... Who ever comes up with the coin
for this beast, will get one of the best built Bugs around.
All the best with the sale mate.
Cheers Mate, we could move it to your garage.
would anyone know what would be required to get this registered in NSW??
To answer the messages I had yesterday, apparently freight to the east is about $900, as backload from Perth is cheaper. That is not a quote, just what I have been told. And the second question, yes I will separate the engine and sell as roller, but I'm sure someone would love buy the motor off you once they see and here it go. Thirdly, a comment from another member, the photot's don't really do the car justice. The body is immaculate and only has one minor dent on the bonnet where a ladder fell on it, and no rust anywhere. Thanks for the interest Paul.
Sorry my pm's aren't working. could 'SICK68'and 'AUSSIE' send a message to my mobile so i can answer your queries. leave your number or an email address. cheers paul 0411277971.
