What oil are you Quaife equipped boys running?
vassy66T1 - December 6th, 2012 at 04:56 PM
Hey
Interested to hear feedback on the options for a VW transaxle with a quaife fitted.
What are you running or what have you run?
Wjich has given the best performance in your opinion?
Marcus
Craig Torrens - December 14th, 2012 at 02:14 PM
I use CASTROL epx 80/90 in my quaife gbox, which is just the stardard GBox oil.
Sides - December 14th, 2012 at 02:43 PM
Wow... thinking about oil already Marcus... great to know the biggest deciding factor isn't "which gives off the most heat in a bonfire" !!!
I had one of Redline's oils in my Quaife box... MT90 it might have been (GL4 either 80/90 or SAE 90).
Also know of people who've run the 'Smurf's Blood' in 'em... Redline Shockproof I think it is, tho Quaife's aren't meant to be as picky as a
clutch pack type of diff like a ZF...
hellbugged - December 14th, 2012 at 04:26 PM
So what you got in with the zf Dave ?
vassy66T1 - December 15th, 2012 at 09:27 AM
Thanks for your responses
I did read from Quaife that they did not ask for anything super special but was still interested in people's own experiences.
Yep Dave S, no bonfire sorry bud
Sides - December 15th, 2012 at 04:36 PM
Quote: |
Originally
posted by vassy66T1
Yeah, cool to hear Marcus... and even better the recent pics show the fire's been lit under your arse instead !!!
Quote: |
Originally
posted by hellbugged
Have Castrol VMX-M I think it is in there now.
Did a bit of research and it seemed to come up trumps - especially for where not necessarily getting up to temps before leaning on it.
MickH - December 15th, 2012 at 05:02 PM
I used to run LS90 in mine when i had it......
20bkombi - December 15th, 2012 at 10:29 PM
Quote: |
Originally
posted by Craig Torrens
I use the same in my 6spd porsche box, with a quaife diff centre.
Just don't use a light grade oil like ATF, as the stub shafts will wear quick and grab on the sprung centre.
