Anyone know the thread pitch size
cnfabo - January 16th, 2013 at 06:34 PM
Hi does anyone know the size of bolt and thread pitch etc of the thread on the t1 IRS trailing arm" for the spring plate" and also the 4 bolts that
hold on the torsion bar covers????
Burrelli - January 16th, 2013 at 06:36 PM
10x1.5
cnfabo - January 16th, 2013 at 10:57 PM
Cheers bro
psimitar - January 18th, 2013 at 12:45 AM
did you also mean the bolts that hold the spring plate to the IRS 'A' arm? Those are M12x1.5
wild baja - January 18th, 2013 at 11:32 AM
the spring plate to IRS arm bolts are M12 x 1.75 8.8 grade high tensile. also amke sure you use high tensile or hardened washers to get a decent
Tension Bolt connnection over the slotted holes
psimitar - January 18th, 2013 at 10:17 PM
Originally
posted by wild baja
Weird cos the threaded hole in the 'A' arm was M12x1.5 when I put new ones in?
