VDO oil temp dipstick senders?
Ryno17 - February 7th, 2013 at 01:11 PM
A bloke told me that there is a guy who makes VDO compatible oil temp dipstick senders on this forum. Anyone know if this is true?
vlad01 - February 7th, 2013 at 01:27 PM
I had or have? one. the whole dipstick is VDO.
I have no idea where it came from or how I got it. All I know it is a VDO dipstick for type 1.
barls - February 7th, 2013 at 01:57 PM
i have one mine came from repco
donn - February 7th, 2013 at 07:30 PM
http://forums.aussieveedubbers.com/viewtopic.php?tid=92996&page=1
barls - February 7th, 2013 at 07:42 PM
http://www.justkampersaustralia.com/shop/vdo-dipstick-oil-temp-sender-435mm-j...
this one with the right gauge will give a better result
68BUS - February 8th, 2013 at 09:57 AM
I cannot comment on the justkampers one but I have one of the summer savers fitted from this link. Took all of 38seconds to fit.
Testing it manually and it sems to work. and when i get out after a long drive and look at how much it has moved it makes sence.
Cheap, easy, quick way to give some piece of mind.
Uses the idiot light on the dash cluster to warn you.
Lateral - February 8th, 2013 at 04:08 PM
I was told by a VDO gauge distributor guy that VDO no longer make the dipstick temp senders.
Regards
Greg
1303Steve - February 8th, 2013 at 04:46 PM
They can be a pain the arse. They are round so they push the oil back down the tube so you can get a false reading, care must be taken to accurately
mark the sender for high level mark and the wires get in the way and can get ratty.
68AutoBug - February 8th, 2013 at 11:51 PM
Originally
posted by Ryno17
hI
Yes there is a fellow who sells a dipstick re4placement temo sender that ia normally connected to the oil llght.. it works great
first it flashes the light then it stays on....
when the oil is TOO Hot... I still use a dipstick tp check the oil etc I've never thought to connect to a VDO oil gauge???
I have another large bright light on My Dash so I can see it go on. Excellent.
68BUS - February 9th, 2013 at 12:21 PM
Re pushing the oil out for measuring levels. Just keep the og dipstick hamdy for checking levels.
