stupid question
clyve - March 14th, 2013 at 08:00 AM
can anybody pls tell me if a 1600tp squareback engine can be stripped to thhe basics and built to fit a type 1, if so how hard also would a squareback gearbox fit the bug.
thanks for the help
bajachris88 - March 14th, 2013 at 08:20 AM
I'm running a 1600tp squarback engine in my baja as a type 1.
Where the oil filler is for the type 3, you can buy a $20 dip stick for converting the type 3 filler into a type 1 style dip stick.
The rest bolts on. For my dog house oil cooler adapter, i had to drill 1 hole wider (the one that dangles over the cylinder 3 barrel) for the stud to pass through then whacked on the nut.
The rest of the gear just bolts on. There is no boss in the type 3 case for a oil pressure sender in the type 1 position, thus use the type 3 oil cooler that fits into the type 1 dog house coil adapter to know where the oil is at.
matberry - March 14th, 2013 at 08:35 AM
The tranny will also fit although the shift rod coupling grub screww comes from underneath on the type 3 so best to swap out the hockey stick to a type 1.
clyve - March 14th, 2013 at 09:21 AM
thanks guys, a good day:cool:
