I have a Type 1 cam with 89C stamped at the end......anyone know the specs ????
Craig T
Closest I've got is an Eagle Cam 89 , not 89c
89 314º 0.390" 9.91 Dual lobe
321º 0.404" 10.26
C89 is a scat cam, but not 89C.
Dial it, in an old case, rank and pulley and you will know what it has.
Craig , the cam is from Scat . This is their FK 87 equiv. grind with 318 running dur. , 274 @ .050 with .410 lift . The C is for stroker clearanced , ROD.
SCAT
Cams for use with 1.4* and 1.5** rocker arms
C85* 330º 294º 0.574" 14.58 108º 5500-8500rpm; competition only
C89** 325º 269º 0.618" 15.70 108º Drag race competition
might need 1.5's from the book
web cams also make a 89c with 310/585 duration n lift they say for drag race only lift is with 1.5 rockers
I should have mentioned in my first post that it is a regrind standard VW 113 camshaft........not a billet grind.
lift is .350" on all lobes.
Looks like I'm going to have to set up a case and crank etc and start measuring
