Hi guys, since my steering box is chagged and I have read that the TRW ones are no good does anyone know much about a R&P conversion,things like
what rack to use,lock to lock yadda yadda..are the buggy ones up to the task for my circuit bug...I have searched the net but have not found
sufficient material on the conversion...
Any and all info would be great..
Fabo...
Is definatly doable, alot of measuring and drawing to get it spot on.
The buggy racks such as wright and saco would be fine in a track car. ratios from 1 to 1.5 turns lock to lock, which is pretty short. (2 3/4 turns
stock?) but alot of the buggy guys prefer it, improving reaction time. how big is your steering wheel?
If you are using it on a track I think it would be pretty good seeing as you have smaller tyres.
the OEM racks that are popular are old camira, 2000 ish daewoo larnos (what i have) and mk1 golf, check smileys thread. Problem is these are hard to
get between stock shock towers.
BAJAWES used to have a huge thread on the subject, I used alot of the info within to get mine right. cant find the link right now, maybe someone
else can help with this
http://forums.aussieveedubbers.com/viewtopic.php?tid=23861
this may be a good start
^ That is a great read!
1+ I see that i have read it before, I don't remember it though
I love racket peanut steering! its trouble free for such a long time.
I am doing it at the moment. Check my build thread out if you are interested.
Smiley
Many ways to skin a cat doing this but most people find that a rack which has the tie rods attach to the centre of teh rack gives more clearance that
a rack with the tie rods tacched to the ends. Also easier to change rod ends and the rack boots last longer as they only move linearly.
Volkszone is also a good source of info as loads of people have done the conversion over there.
Also, the vehicle isn't gonna be used on the road is it? If so then a vehicle engineer will need to sign off on the design and finished article.
It would be nice if someone set out a line up of standardized engineered rack conversions.
We have at least one person doing the same with brake upgrades.
There are a few kits available, most of the kits come out of the UK.
Red9design wishbone kit.....
Thanks guys I'll keep poking around..I would prefer to do the Greg macky mod but just have to find I good steering box,but rack is second
option....
Thanks...
