In my daily driver, 1969 beetle. As I accelerate there is a knock that comes thru the floor, no matter how gingerly I let the clutch out or depress
the accelerator the noise is there and loud.
So what am I looking at?
Front transmission mount?
Thanks for any responses..
yep or even the gearbox mounts on the cross member have gone soft or separated.
Thanks, for the response.
So does this require engine removal , in order to replace the nose one mount?
yes and no
You can just loosen the bolts on the gearbox brace to move the whole thing back far enough
I was able to change mine this way - but it died in 6months any way
Then I put a Porsch style Berg mid mount on and that fixed the sucker
rear mounts mean engine out as you need to get inside the bell housing
Definately check the front tranny mount. Mine was doing the same. If its worn replace it, or maybe the bolts have loosened and just need tightening.
Check all shift rods also and the coupling under the rear seat
