About 10 weeks ago my engineer replaced a rear wheel bearing. Torqued it up to the specs from memory over 200 lbs even near 300. whatever it was.
The swing arm is Panther custom one. I had a new axle on hand as well as the new bearings. Today I had my Cv boot repalced and my mechanic inforemd
me that there is slop in the wheels bearing. couple of mm's.
Why would this occur? Whenever I've had one replace dits lasted 10 years or more. What would cause this?
The wheel bearing could have been a cheap and nasty one or it was installed incorrectly and damaged during the process, what is the layout of the trailing and what is the bearing configuration, does it use a cartridge bearing , what was the brand of the bearing .
If your trailing arms are anything like VW ones they can flog out which will give you slop in the vertical, you can also get oversize circlips to
remove in & out movement.
Thanks guys. I do know that a very good engineer/mechanic did the other side LHS a few mobnths ago. We got a bearing kit supplied by Panther trikes.
The kit included a new axle, two bearings and two journals. The journals were crap in that they were undersize. He made up two new ones on a
lathe.
So I had a second kit ready to do the other side RHS- the side that has slop in it now. But at that time (June 2013) there was no slop and no problem
detected. So we left it.
4 weeks later I'm getting the trike frame strengthened at another engineering place and they said the wheel bearing RHS had slop in it. So then I
supplied the kit. They only used the bearings and the journals in that kit, didnt use the new axle.
Which poses a few question. Firsltly I suspect they didnt realise like the first engineer (who seemed real thorough) that the journals were too
small. I think I'll have to return to the first engineer to get it done correctly.
I dont know the bearing make or details. The swing arms are alloy custom box section Panther trikes exclusive.
Thanks fellas for your replies.
It is very hard to comment if we cannot see the type of bearing configuration, when you talk about journals and as a machinist I think about bushes not ball or roller bearings, as to the fact they were machined seams strange, any photos of your set up.
No pics yet VW060. But the guy that did the bearings a few weeks ago in that wheel has offered to pull it all apart again and fix it. good. I have a new axle too. in 2-3 weeks he will get the trike and I'll be there to watch. will take pics then too. regards. Tony
check to see if the bearing housing has a 311 part number
Does it have type three rear wheel bearings?.
it is modelled on type 3 axles. Panther however make their own swing arms from alloy box section.
Here is a kit I have from Panther ready if required by the engineer next week. The bearings are roller type Nachi 6206C3 and NU206EG C3. same as you
advised 68autobug.
Interesting about the thicker circlip. anyway will be present when he dismantles it all. and will emntion the moly lithium grease. might be a
greasy version of the pills I used to swallow. lol
The bit that holds the bearing into the axle housing what part number does it have?? 111 or 113 is beetle 311 is type 3 the housing are very slightly different and cause the issue u are experiencing.
Use good quality wheel bearing grease......NOT moly. Moly tends to cause the balls to 'skid', rather than roll [nothing worse
thanks guys. will be getting it done tomorrow - Friday. will rpint this out and use it.
took tweety trike to the engineers. engineer took it apart. when he began he noticed the axle nut loose. the bearings were cool to touch even after
50kms. We had those spare bearings, seals and avle but after an assessment they werent needed. Torqued them up to 220lbs and no slop at all.
Maybe they settled in? All I know is it was nice to ride without the slop.
220 they can still come loose. A lot of the guys here do them up to 300 ft-lb
yeh, will take a note of that. and he did use wheel bearing grease. thanks for your replies guys.
