I want to take my steering column out so i can remove the body of my 66 beetle. Do i have to take the steering wheel off? -if so what else- i have removed the petrol tank to undo the front bolts-=
Undo the flexible coupling at the steering box,the column should then slide up enough to lift the body.
If the couplers 2 bolts to the steering shaft coupling are removed then body should just lift straight up. If in doubt tho pull the steering wheel up
and use a mole grip on the steering shaft to keep it raised outta the way
is it hard to completely remove the steering wheel and shaft because i am selling the body and keeping the parts?
