does/has anyone used wheel adaptors?
VWFOOL - October 7th, 2002 at 12:02 PM
i understand some ppl may be against the use of wheel adaptors, and i know they are illegal, just wondering if anyone has used them before and if they had any commments or info about them, where they got them, etc?
thanks for your help
68AutoBug - October 7th, 2002 at 04:50 PM
I have never used them, but as far as I know, they are for sale and used in many countries. They were legal in South Aust in the 60s & 70s, not sure now. They are still available in the UK... and probably still legal... I have never read anywhere of failures....:thumb
vw54 - October 7th, 2002 at 08:08 PM
Sam
VVDS has them available now
Josh - October 7th, 2002 at 09:50 PM
Are you talking about the wheel adaptors for the rims?
When I purchased my '67 Beetle about 2.5 years ago, they had a set of adaptors on them. I took them off to make way for a set of Dragway Mags. I have them sittin in the shed. If you are interested in them, let me know
thesnells@bigpond.com.au
:cool:Josh:cool:
VWFOOL - October 9th, 2002 at 03:27 AM
i know i can get them in the UK and they r legal there,
im just wondering if anyones used them b4.
hey dave,
do u mean VVDS just got them in cause i rang them about them back a few months and they sounded like they were never going to stock them again.
are these to fit wide 5 to 4 stud beetle?
josh, wat wheels will they fit to ur beetle, was ur beetle 4 stud?
im after wide 5 wheel to 4 stud beetle, i have emailed u too...
the pic below shows some american style ones, id rather the stronger UK built ones though...
thanks for ur help
sam:thumb
VWFOOL - October 9th, 2002 at 03:31 AM
like these ones from Machine 7 in the UK...
:thumb
vw54 - October 9th, 2002 at 07:33 AM
I wouldnt use the ones in the first pic... there pressed steel and i dont trust them.
VVDS are similar to the ones in the second pic they are 4 stud to 5 stud VW
70AutoStik - October 9th, 2002 at 08:10 PM
Yes, they are definitely illegal, they increase your track by too much and, due to the problems of them breaking, they have been banned. For what the better ones would cost you, you can have your hubs redrilled, or fit components from a later make. I'm sure all three options would require an engineer's certificate.
As for "I've never read about them breaking-" you haven't read much, even the crazy yanks will warn you that they break (there simply isn't enough purchase in the adaptor plate for the studs.)
VWFOOL - October 9th, 2002 at 09:53 PM
yeah i wouldnt trust the US ones in the top pic, but those UK built ones would be good. i think they increase the track by 1cm, or maybe 1 inch, i hav read both measurements.
so ur saying VVDS hav those in stock now?
i will call them tomorrow...
has anyone else used these things?
70autostick, wen u say fit components from a latter make, wat do u mean? i hav 4 stud wanting to go 5.
is it possible for me to go back to 5 by any other means?
i hav IRS welded in back of the oval and ball joint front end with 4 stud discs.
is there anything that can be done?
i hav my original Oval pan though, no chassis conversion.
thanks guys
:thumb
