does any body know who might do this conversion in oz
a 2.1 wasser boxer crank in a t1 case
You with a grinder.
your a funny guy mick
You're actually better off cutting the water jackets from a wasser and using the case and crank for a much stronger bottom end.
I think Volksworld magazine covered this 3-4 years ago and I've seen it done by guys on Volkszone.com.
Any machine shop will be able to face off the rough cuts of the water jacket in their mill
isn't there a lot more machining then just water jacket removal like stud replacement and barrel machining and when you live in Townsville everything needs to be sent away or it gets f$#!ed up and freight is a killer if you have to send it away to get done properly
Why not just run a Type IV?
They are bullet proof in the bottom end and are probably easier and cheaper to come by then WBX parts.
Unless you have them already of course. There's no machining with a Type IV though.
Smiley
Your post just sparked a memory of what I'd seen in the past. If after some research it turns out to be too much work then at least it's only your
time and no money has been lost.
I do understand how hard it is to find good 'any' trade these days so the simpler the task the better off you are.
Is a Rod Penrose engine out of the question?
http://www.rodpenroseracing.com.au/
Just looking at it from another angle…how hard is it to mount a radiator? Just a thought! Dave
well I do have a 1.8 lt kombi motor but what sort of hp numbers do you get out of them and what sort of reworking of the motor is needed to get 130hp or so at the treads
