Advice need re motor and box
grimbear64 - April 27th, 2014 at 09:08 PM
hi guys i have a 73 single cab without motor and box i have 73 beetle 1600 twin port motor and box can i put these in as they are newly rebuild came out of a wreck i got have type 4 motor and box but they need rebuilding and keen to get this one on the road soon then later any help would be great cheers
Joel - April 27th, 2014 at 09:23 PM
A Beetle engine doesn't have the mounting points for a Kombi engine cradle.
You can buy these dodgy adapters which pick up the oil pump studs which is a really hokey fix but its its only temporary you would be ok (not a good idea supporting the engine using the 4 8mm oil pump studs)
Also you will need a Kombi intake manifold, a bug one doesn't have the port for the brake booster unless its from a Semi auto.
You're out of luck with the gearbox though, Bug ones don't have the mounting points on the top of the bellhousing to fit a Kombi and the nose cone and mounting area are completely different.
Also with a bugs gearing a 1600 would struggle to get a Kombi moving.
It would be a lot less work to fit the type4 box and just change the input shaft to suit a type1 engine.
grimbear64 - April 27th, 2014 at 10:52 PM
hi joel thank you for the information think i will go back to plan A. l have the right motor and box the motor just needs a rebuild will jump on the inter web order bit now lol
