Hey Guys, new to the scene and been searching through the threads but haven't come across anything that helps me.
i have a 1968 beetle 1500 thim wanting to lower it.
im in qld and all the engineers seem to say to me is it needs to come with a statement saying the parts are for road use from the manufacturer.
alot of you guys obviously have experience in this field so if you could point me in the right direction or give me advice im all ears.
i want to narrow the beam to tuck to get it real low. but im under the impression its not legal. so i ask how can i legally lower.
HERE WE GO AGAIN.
Is that Pandora's Box opening up next to a can of
worms .
Simple answer is MANY cars have been lowered legally
You need to talk to a VW knowledgeable engineer.
Join a club, chat to some propper work shops.
It is just a LONG winded story to give a simple answer on a forum
I think the simple answer is you need 100mm clearance
Narrowing is a whole different story, and is a lot harder to get approved
you guys are enthusiasts hence why im asking....
i dont know any proper workshops nor vw engineer hence asking the question....
thanks guys
you have PM
By NCOP rules the lowest part of the chassis, or body if it sits lower than the chassis, is equal to or greater than 100mm.
Also, the track can be changed but I forget by the amount. The engineer I had sign off my seat frames and seatbelts said the adjusters didn't concern
him and qould be fine by QLD transport rules, and he used to work for QLD transport. My IRS conversion however does need citing by a QLD transport
engineer as a valid mod but he said as the job was well done it wouldn't be an issue.
Unfortunately, as with many Oz regualtions, they aren't very definitive and as such a lot of the time it comes down to the individual engineer as to
whether he thinks it's acceptable. One may say yes and another no.
I spoke to the Queensland main road engineers and he stated that no narrowing of the track is allowed out side the 25mm over track limit, i think you are allowed to lower your car up to 1/3 reducion in bump stop measurement, dropped spindles can be run legally if you can find an enginer to sign off on them, will required to be tested at his disgression.
can of worms yup yup
In other words. Open your wallet & pour it into an engineers pocket & he may okay your mod. BUT if you get sent over the pits by the police,
another engineer may NOT approve the parts used, that were designed by one engineer and approved by another engineer. Guess who wins in this game.
Oh, and unless fitting a disc kit to an LP bug then narrowing is just a 'looks' thing. From a safety standpoint it makes the car handle worse at speed.
The engineer accepts responsability for the mods he signs off on, if you have a agreement before you start and the mods discussed in detail showing him all the parts you intend to use along with any paper work there should be no issues, i disigned my front and rear disc conversion on my early beetle, this included billet hubs that i machined out of aluminium along with the steel brackets, CAD drawing were done and submitted, calculations were done for the the brake bias to take into account for the increase of front and rear braking , when i fitted them to the car the engineer carried out the brake test and inspected all aspects of this mod, passed first time, blue plate attached. a total of 18MM over track when it was finnished, this let me keep close to the scub radius of the standard car.
See Buggaup thats how easy it is. So grab a six pack and get into it this week-end. Happy motoring. Did notice there was no costings attached to the easyblue plate option?????
There is no easy blue plate option if the engineer is doing his job only a lot of back ground engineering that can achive the outcome i got along with the correct fabrication of the components, cost was about $500 for the engineering and about 200 hours of my time.
I lost control of my kombi the other day and crashed into a pre school, my front wheel was 2 inches away from hitting a sleeping child!
All I can say is thank god I was running a narrowed beam.
lucky you were
thanks guys appreciate it,
i all for the lowered look and just want it low haha
if i can sit it that low without narrowing then im all for it.
Tell me about it dude!
Was thrown at me by a turtle driving a slammed ragtop beetle .
All revelent to the question
Ive just fitted a 4 in narrowed beam to my 59 Beetle and want to know peoples previous experience on cutting the drag link. The passenger side seems
easy, determine length, cut thread inside drag link with a tap, install tie rod, On the drivers side the tie rods are crimped to the drag link, I want
to know what you've done in the past.
thanx in advance.
Chris
