Hey guys
I recently put a 67 beetle gearbox in my 61 then fitted a 1600 twinport motor.
Since doing so the motor sits crooked in the engine bay, the tinware has about 2-3mm clearence from the body on the driver side. But the passenger
side has about 10-12mm clearence.
I have been told to change the nose cone on the gearbox but dont knkw the definite solution!!
Please help!
Check your gear box mounts make sure they aren't torn/damaged, Got any pics?
Box has been reconditioned
all mounts are new etc
Frame horns could be bent or the rear of the body.
Kev
There is a bit of clearance in the mounting holes usually from wear. I'd say if you loosen everything off you'll be able to realign it.
Check the gearbox is on centre, did the original engine sit in the centre of the engine bay, some times you have to loosen all the body bolts and move the entire body over if everything else checks out ok.
Everything was okay until I replaced engine and gearbox
as they said, loosen ALL gearbox mount bolts and maybe the mount frame across the horns..You may need to use a jack and bars to move the engine.
Was it a split case non synchro first gearbox originally?
Silly question but did you grind the box out for the flywheel?
No I didn't
I bought the box from a guy who had it running in a 67 with a 1600 twin port
I only ask because if the flywheel isnt sitting in the box correctly the engine might not be mated to the box?
Was it a non synchro box that you swapped out?
Get the rear up on axles stands and lay under the gearbox so you can see if the gearbox sits parallel with the framehorns and if the engine has
properly mated to the gearbox.
This will let you know where the issue lies as could be gearbox mounts or could be the engine not seated properly.
Easiest way to find out really
He's been told to change the nose cone, my guess it's a '60 or earlier chassis with a crash box. The mounts and horns vary and adapting the later
box isn't always easy.
Have a look where the gear selector goes into the hole in the pan. It should line up in the middle of the hole and another area to check is that the
axle tubes have plenty of clearance for the boots. It's a good indication that everything is in place.
You have already got a few possible outcomes from suggestions,mine would be if everything is correct and the engine is already out of the bug,pull out the gearbox and then see if they bolt up
