So I have a hot drum, but I'm not sure what is causing it.
Car is a 1964, but I believe it has a later model swing axle.
I do have the car dumped two splines on the outer.
The indicator was the car burning through brake fluid. We though it was a leaky brake cylinder so we replaced the front two (As one was suspect) and
moved to the rear.
The rear didn't appear to be leaking at all but we thought we should do all four at the same time. It was at this point we noticed that the paint on
the rim on the passenger had bubbled from heat, and we believe this may have been evaporating the brake fluid.
We then tried to remove the axle nut and that was a no go. We had so much lever that we started turning the engine over with the handbrake on
(probably not the best adjustment I will admit) before we could break the thread.
The car sat for 6 weeks and we come to tonight. We heated the nut (and subsequently the hub) with a heat gun and tried to break the thread using a
cold chisel. This didnt work so we gridded the nut until we could open it with the chisel.
At this point ignited brake dust fell out of the inside of the drum (from the grinding and heat gun). We looked at the inside and didnt see any
purpley heat marks to imply the brakes were locking on. We also pulled the seals back and couldn't see any of these marks on the ball bearings
either, they also appeared to be intact, there was blackening on the inside of the bearing seal that slipped around the ball bearings where it was in
contact with the axle. It's worth noting there was still a fair amount of oil on the bearing, even after sitting for 6 weeks.
So my dilemma is what is causing the heat? The brakes don't appear to be locking on and the wheel bearing doesn't look like it has collapsed at
all.
My tendency is to think that when I last worked on the drum assembly, I have over tightened the axle nut and the tightness against the backing plate
has caused the whole unit to heat up. (Possibly even igniting the brake dust and having that smoulder inside the drum as well. After all, we did
ignite the dust just from the heat from the grinder and heat gun).
Has anyone else had a problem with the drum heating up? Does this sound like the culprit?
Thank you for reading,
John/Allbones
To be doubly sure the bearing is OK I'd remove it and turn it by hand to listen or feel for rough running.
I had a bad bearing on the front that made the hub to hot too touch and that was a sod to get off the spindle.
Anyway, if the bearing is OK and getting a good supply of oil then overtightening is probably the issue as it'll cause the ball bearings to be pushed
against one side of the races.
There are only two things that will cause the heat, a bearing running without oil and failing or the brake shoes dragging, did you check that the drum was free before you tried to take it off, you need to remove the backing plate and inspect the bearing, if it has discoloured then you will need to replace it, you can get a cheap flogging spanner that will remove the nut without issues, http://www.vollks.com.au/store/VW-Axle-Nut-Removal-Tool-36mm-Type-1-2-3-and-4... works every time, try running a sealed bearing in the axel and remove the out seal and pack it with grease. probably last longer that the normal bearing. when you run that sort of camber. over tightening the axel nut will not cause the backing plate to rub, it would be obvious it it had.
You need a puller to remove the bearing, you should be able to inspect it once you get the bearing cap off,, if is getting that hot it will be discoloured.
Have you ever replaced the master cylinder or put a kit through it? Sometimes the small relief ports get partially blocked up with sludge and can drag the brakes when hot but seem ok when they cool down..
"A worn out brake hose usually does not leak, it collapses internally (this is by design). When this happens, it will prevent brake fluid from
getting to or leaving the wheel cylinders which will either cause a pull to one direction when braking or a sticking brake. Normally, when one brake
hose is going out, its best to change all four at the same time. Here's why: if one hose has gone out, most likely the other hoses are the same age
and have been subjected to the same amount of wear and tear and are bound to fail soon thereafter. Also, as you will need to bleed your brake system
after installing even one hose, it's easier, faster, and cheaper to only have to bleed your system once instead of after every new hose."
Guessing this is my problem in a nutshell. Straight from Das Resto site, on the brake line page as I went to order. Very helpful haha
Yeah, we double checked the bearing, we are pretty confident it is the lines.
