2250cc hp
giturner1703 - June 10th, 2014 at 08:45 PM
Just wondered whether 85 hp at the wheels was a reasonable figure. Don't know any engine specs other than its running twin dellorto's & 2250cc
Bizarre - June 10th, 2014 at 08:48 PM
possible
Old motor with leaky stock heads, a mild cam and restrictive exhaust could/would produce less
A lot more info would be required
matberry - June 10th, 2014 at 08:50 PM
Lots of variables there, but it is'nt a lot for that size engine, my 2.0 litre type 1 with 043 VW heads makes 122 at the wheels on a bad day
vlad01 - June 10th, 2014 at 11:50 PM
I am thinking good combo at that size 160hp or more @ the flywheel, what ever that is at the wheels.
DakDak67 - June 11th, 2014 at 06:03 AM
Originally
posted by vlad01
more like 125-135 flywheel, 100-105 rwhp
Governor - June 11th, 2014 at 06:49 AM
My 2007cc showed 100bhp at the wheels on Leons dyno.
Its not just the size, its the combination of parts.
Anyone can build a motor, its knowing what works!
vlad01 - June 11th, 2014 at 10:46 AM
Originally
posted by DakDak67
posted by vlad01
I said good combo, that sounds like average at best. Or is that expectation too high for a t1 engine lol ?
DakDak67 - June 11th, 2014 at 11:37 AM
I would like to know how to get 160hp from my 2276 with idf's, street cam and heads. I'm all ears ...
matberry - June 11th, 2014 at 11:38 AM
My 2332 with VW non welded heads and 44x38 valves made 140+ at the wheels, so you're not being unrealistic Vlad
matberry - June 11th, 2014 at 11:40 AM
And since we're on the street Chris, that was under 10:1 comp and totally streetable, 48 IDFs or Dells will do it.
DakDak67 - June 11th, 2014 at 12:20 PM
Originally
posted by matberry
we'd better step up from 8.5:1 and 44 idf's next build then Matt. That said, your attention to detail and tuning is pretty rare ,
I'll still safely say the average built big engine has no where near 140 on the wheels. Anyway, I would be happy with another 25 HP !!
Craig Torrens - June 11th, 2014 at 12:59 PM
Originally
posted by giturner1703
At what RPM was the 85hp ?
Do you have the dyno chart at all ?
Don't fall into the trap of only comparing peak HP numbers.
vlad01 - June 11th, 2014 at 01:30 PM
Originally
posted by matberry
rule of thumb.
liters = potential power x 100 for real R&D'd NA engines.
it applies to pretty much all engines.
more obtainable figures for general performance builds is about 75hp per L
bog stock engines these days make 60-70hp per L
DakDak67 - June 11th, 2014 at 01:39 PM
I'm looking forward to the Dyno day at Leon's. There will be several 2.2+ litre street engines running , I'll post results for the OP to compare .
vlad01 - June 11th, 2014 at 01:44 PM
Originally
posted by DakDak67
I have seen one t1 race engine 1500cc make 186hp at the flywheel.
150- 200hp 2270cc is not uncommon for a good combo for t4 engines which makes power everywhere in the rev range.
bajachris88 - June 11th, 2014 at 01:57 PM
And particularly if you live in the US. All quoted dub engine hp outputs there are 50% greater. Must be better air in the northern hemisphere
Craig Torrens - June 11th, 2014 at 02:33 PM
http://forums.aussieveedubbers.com/viewtopic.php?tid=25222
vlad01 - June 11th, 2014 at 03:03 PM
Originally
posted by bajachris88
are you talking about HP and PS? or just kidding?
I know a lot of people argue the metric hp is way different to regular hp.
its like 2.4% different.
2.4% is double!!!
giturner1703 - June 11th, 2014 at 08:46 PM
I haven't got dyno sheet, but from memory it was about 4700rpm. I know there are a lot of variables that come into it, just didn't think 85 hp was
that good for a 2250cc engine. Having said that, I'm new to this big bore/stroker stuff!
MrSpeedy - June 12th, 2014 at 09:10 AM
If it's making its power at that low rpm, it's probably a very mild combination. A friends 2l kombi motor on webers, mild cam etc was just under
80hp at the wheels and is a strong motor for a comparison point.
Bizarre - June 12th, 2014 at 10:13 AM
85 ponies at 4,700 ain't to be sneezed at.
Could be a nice torquey streeter that is non stressed
bajachris88 - June 12th, 2014 at 10:25 AM
Makes sense. Back to fundamentals the power is equal to torque x rotational speed.
So you could have a HUGE torque (like a typical diesel) come about at a nice and low RPM, but because of the low revs it will equate to a small HP.
vlad01 - June 12th, 2014 at 11:01 AM
Originally
yes, that means it can haul weight without slowing down much.
but actual power is what give you acceleration. but more importantly is how the power curve looks, if its broad it will give the best performance, if
its peaky, then is useless most of the time until it peaks like ricer cars do.
bajachris88 - June 12th, 2014 at 11:18 AM
Originally
posted by vlad01
But the single ports have better buzz off the line than the DPs :P with less HP!
vlad01 - June 12th, 2014 at 11:49 AM
yes, thats cos its boarder at the bottom end and fall off quicker at the top end compared to dp gearing is also part of the equation.
I have not see direct comparison between the 2, but I bet the sp has more torque thus more hp available at the low revs than dp does.
if you have 1000 torques and 0rpm, there is 0 hp and it does not move.
good way to look at it if everything else is equal and disregarding the little factors like gear ratios and crap like that
double the hp = double the acceleration
double the rpm but same hp(halving the torque to equal)= same as before
double the torque same hp(halving the rpm to equal)= same as before
but we have torque curve and thus power curves, so in reality acceleration and top speed depend on the curve and gear ratios and other factors like
weight etc..
fish26 - June 12th, 2014 at 02:06 PM
85whp @ 4700rpm os ok, what are the Torque figures? Do you like how it drives, does it put a smile on your face, if you answerred yes, what difference
does the amount of HP make?
This whole thread is based on speculative information, no engine combination info and no dyno sheet.
What exactly is a 2250cc, did you buy the engine with the seller telling you the information without substantiated evidence?
Two different engine builders will build two different engines even if the combination of parts are the same and theoretical engine conbinations and
Hp calculations are only a guideline of the outcome eg. mumbo jumbo.
More information please, even just for curiosity.
vassy66T1 - June 13th, 2014 at 09:14 AM
It makes sense to me now why T4 motors have good torque ... it is because they flow just the same as a single port T1
fish26 - June 13th, 2014 at 12:55 PM
Yeah, thats exactly why they make good torque..............
ian.mezz - June 13th, 2014 at 01:32 PM
85 good, you don't really get to rev past 5000rpm on the streets to often, just get out on the road and enjoy it .
vlad01 - June 13th, 2014 at 07:07 PM
Originally
posted by vassy66T1
Yes t4 have much more efficient head design.
a good t4 combo will make power and torque everywhere, much more than a t1 can.
