ok quick question
can you change a 67 brake master cylinder int the two style one of say a 72 beetle?
is it easy?
worth it ?
thanks
clyve
Doesn't work unless you're going to discs on front.
Easy yes..... Need resivoir, lines to master and fittings to match. Also brake hard lines.
The dual MCs you can buy these days aren't sold as disc or drum specific and so you can fit a dual MC. Fitted one to my 59 and works just fine.
