Stock 1600 tp solex carburator. When shes cold and I take off down the road it cuts out when I stop, this lasts for quite a while, when it warms up
its okay but the idle rises and falls. At idle I sprayed carby cleaner around the shaft of the carby etc. but doesnt seem to have any air leaks.
Mixture, idle screw perhaps? Im going to strip the carby and put a kit through it on the weekend. Is a cleaned kitted Solex better than a new Empi
pict carby?
air leak more than likely
Spray around the all the manifold joins as well mate, I agree with Barls sounds like a air leak. Done all the usual timing/points checks as well?
Yeah the points and the timing should be sweet.... I think...
