Hi all, we have just put a '60 Beetle back on the road after many years of it sitting. The gearbox seems to whine a bit when in 3rd or 4th gears.
Is this a general sign of age / wear and tear, or is there something more sinister coming? The car is only going to be a low-use weekend driver. If
it should still drive OK for a while thats good, but all info appreciated.
Is there anything we can do, short of pulling the thing out, to assist the situation?
Thanks.
Certainly could not hurt to give the motor and gearbox a change of oil if been sitting for long time.
Put some Nulon G70 in it, it worked wonders with my sons 74 http://www.nulon.com.au/products/Specialty_Products/Manual_Gearbox_and_Diff_T...
do a few kls and dump the oil do this a few times to get rid of the crude in the box
then add the nulon good stuf
x 4 for Nulon
When we bought my sons 74 1303 it had an original granny spec gearbox, whinny and hard to change back gears when cold, the Nulon fixed all that.
It could also be the mainshaft bearing (the one behind the nosecone you can replace with the gearbox out) if the whine is there is all the gears?
If it is only a weekender runabout I wouldn't be too concerned. Agree that an oil dump or two would be a great move. If it is whining and slipping outta gear then time to consider a reco box. Mine used to whine like my mother in law but kept on giving me reliable motoring. Mind you it was dumped in the guts and the blade end of the axles and the fulcrums were pitted and knackered but no loss of drive or crunching. Drove it until I fitted a Rancho to suit the 1904.
Thanks all, the car will only be an occasional driver (club trips and sometimes to work etc), doesn't slip out of gear and is only whining in 3rd and 4th. Will contemplate an oil change for it, have more issues now. Thanks!
