blinkers
roach - February 5th, 2015 at 04:59 PM
When i was driving to work this morning in my 62 bug every time i used my blinkers they would flash twice and then just stop.The blinkers had stopped completly by the time i got home i bought a new flasher can you can hear it working in the nuetral position but when you move the lever L or R nothing happens.Any ideas anyone.thanks Tony
LUFTMEISTER - February 5th, 2015 at 06:26 PM
Bad earths or bulb blown in circuit.
psimitar - February 5th, 2015 at 07:51 PM
The flasher shouldn't be heard working when the stalk is in the neutral position. Possible dodgy stalk. If you find the 3 wires for the stalk then you can jumper between the Black/green/white to one of the others to see if the flasher relay and lights work properly. If they do then defo the stalk otherwise bad earths or faulty wiring.
roach - February 5th, 2015 at 07:53 PM
Thanks for the help will check it all out. Tony
roach - February 8th, 2015 at 06:24 AM
FIXED THANKS TONY:smilegrin:
