I have a 59 beetle with a 4in narrowed beam and drop spindles.
Ive heard theres a way of setting up the position of the adjusters.
Whats your experiences/opinions on this?
Cheers.
I got mine up on large retaining wall blocks so I could easily and safely get under the car.
I also made sure the adjusters were in fully raised position before I started. Then I used a jack to take the weight of the car so i could wind down
the adjuster a few turns each and then let the jack down to see where the car settled. then just kept doing this till at the height I wanted plus
slightly higher than I wanted to allow for the suspension settling.
